Ron's Computer Videos
65scribe...
WHO DOESN'T??? :)
Dec 5, 2025
Arbystpossum
65scribe...
Absolutely love this guy.
Dec 5, 2025
mac27
iBook G3 Clamshell display replacement failure, a cautionary tale
i assume you mean that just the display stopped working? On mine everything else still works (drives, caps lock light, speaker/chime)...
Dec 5, 2025
65scribe...
General Chat
If you could name one person who ABSOLUTELY exemplified the title of "True Macintosh enthusiast," who would you say? <nods head slowly>...
Dec 5, 2025
Might be worth trying to at least confirm that the ground pins are where the schema expects them to be. Would at least increase the...
Dec 5, 2025
mac27
I've been going back and forth with the seller, and they suggested this. It makes me a bit nervous, as that also assumes there are also...
Dec 5, 2025
Try my test of many short captures. If my units is 9% error rate, but your closer 50%, that is different might be setup, reel skid...
Dec 5, 2025
MeTheMac
Huh. I guess this is what happened to my magically stopped working clamshell after I swapped the screens from an Indigo one...
Dec 5, 2025
Could you clip the arms off the connector so you could insert it the proper way? Of course, that assumes all the pins are actually the...
Dec 5, 2025
That is correct for this version, but in the next it will be simply threshold limited.
Dec 5, 2025
