P
P-car
yes, that was my worry - not a macro. thanks
Dec 16, 2025
T
ThePhage
I see that the Qp level now ranges from 15 to 29 (instead of 39) and it no longer loops back to 20 when exceeding that range) = Good!
Dec 16, 2025
Oopps, I had the red offset wrong: Default values should be: WBAL (current defaults) 2.0 592,256,256 1.5 560,256,256 1.0 528,256,256...
Dec 16, 2025
It will not. Only the AZURE-1228MAC 2/3" 12mm F2.8. The lenses need to be designed as a macro.
Dec 16, 2025
T
ThePhage
Does this WB settings table take into affect the Red "Trim" you had where 496,256,256 was "default/white."
Dec 16, 2025
P
P-car
Ok, I just came across this M12 12mm 2.8 lens on AMAZON for $9.99!!! (Please tell me, that, IT MIGHT work. For $9.99 I've got nothing...
Dec 16, 2025
BlueSCSI Toolbox
Great! Thanks for the feedback. I'll add the 1.0.2 back to the page and take a closer look at why the beta is failing (thats why it's a...
Dec 16, 2025
mmaseda
BlueSCSI Toolbox
That worked !! Thanks
Dec 16, 2025
BlueSCSI Toolbox
Ok might be an issue in the beta then - please give the last release a try https://bluescsi.com/HD1%20BlueSCSI%20Toolbox%201.0.2.zip (1.0.2)
Dec 16, 2025
P
P-car
thank you.
Dec 16, 2025
My three units.
Dec 16, 2025
mmaseda
BlueSCSI Toolbox
That’s the same version I was using.
Dec 16, 2025
P
P-car
ok, that clears up my confusion. thank you and lastly, how do I know how much to "cut out" and raise the camera unit?
Dec 16, 2025
