R
rdesros
Yeah, I noticed that too.
Dec 19, 2025
But I noticing, V7.6 doesn't want to go below Qp 20. Looking into that. It is Type A bug, only.
Dec 19, 2025
Bit-rate is depended on the Qp value. Lower Qp, higher bit-rates. If you values below 22, you adding risk of capture failures. Rare...
Dec 19, 2025
R
rdesros
Yes. I forgot to mention that Qp is set to the lowest value.
Dec 19, 2025
P
P-car
fantastic!! Ok, so to get 25-27 Mbps, I just set it to the lowest possible number - 15 for example - and let the also do the rest, correct?
Dec 19, 2025
N
NJRoadfan
Looking for the document "Macintosh Worldwide Development: Guide to System Software"
Looking at period documents, this would sold under APDA #M7047/B. I also found references back in 1989 for an earlier document called...
Dec 19, 2025
R
rdesros
@0dan0 Quick update on version 7.6: I’m now getting a steady 25–27 Mbps with the stock lens. Sharpness set to -0.5. There’s still a bit...
Dec 19, 2025
Software | System Software (68k)
I've been researching the Apple system routines that use LongDateTime as part of a potential solution to the 2040 problem. Because it is...
Dec 19, 2025
A very special Mac Portable
Each time I let an eBay auction get beyond me (I set a mental price point and don't go over it), I think to myself "Someone else must...
Dec 19, 2025
