V
V.Yakob
DOS on Mac
But this Socket 7, and the manual doesn't anything extra, it's written simply P133 P166 MXX P200 MMX I didn't see any other...
Dec 21, 2025
[SOLVED] No Dark Castle on Mac Portables?
Macintosh Portable
So far, I've not been successful in running Dark Castle or Beyond Dark Castle on my M5126 Backlit Macintosh Portable. I've tried disk...
Dec 21, 2025
O
omega
My experience is that the shaking is caused by dried or poorly cut film. The gripper on dried film does not fit exactly into the...
Dec 21, 2025
N
NJRoadfan
DOS on Mac
MMX CPUs require split voltage supply. They just won't work in a standard Socket 5 motherboard hence why Pentium Overdrive MMX CPUs...
Dec 21, 2025
speakers
Looking for the document "Macintosh Worldwide Development: Guide to System Software"
I see lots of hits for "LongDateTime" on archive.org. Have you trawled there?
Dec 21, 2025
Bummer. Why didn't they just use a 64-bit integer at that point. It is slightly understandable when the 128K Mac came out. But, by the...
Dec 20, 2025
Mac IIci "It is now safe to switch off your Macintosh"
Yes, you're doing the right things. Here is what the traces look like underneath the chips. Turn off power and check that each trace...
Dec 20, 2025
splorp
FWIW, Newton OS will be affected by a year 2040 problem as well. https://newtonglossary.com/terms/year-2040-problem
Dec 20, 2025
Share examples? I do this all the time, not seeing it.
Dec 20, 2025
R
rdesros
I think I’ve spotted a bug. The capture quality looks fine when starting from a blank movie strip (the white section), but if you begin...
Dec 20, 2025
B
Brutus75
Macintosh II
Hi Guys, I bought an old Mac IIci and it was in really good shape. After turning it on everything worked except for the sound. I was...
Dec 20, 2025
