GreenBar0n
Setting aside the clock signals for the moment, I moved on to the Reset circuit, I definitely have an issue here: UB11 pin5 is fine...
Dec 22, 2025
Mac IIci "It is now safe to switch off your Macintosh"
After you get the message, if you push the rear button, does it power off? If it does, then there's only a couple of possible issues...
Dec 22, 2025
B
Brutus75
Thanks David... especially for the shot of the traces under the chips... it really helped. Unfortunately still the same issue. Another...
Dec 22, 2025
GreenBar0n
The 'main' Xtal has 31.334 MHz written on it, that and the C16M 16.667 Mhz clock is perfectly in speed with the guide. I'm having...
Dec 22, 2025
Nixontheknight
I think the rest of the signals are generated from one of the chips, but I'm not sure which
Dec 22, 2025
GreenBar0n
Are there more crystals than the largest rectangular one? How would I confirm the C3M clock is having problems in this case?
Dec 22, 2025
Nixontheknight
it's that metal looking chip towards the middle of the board
Dec 22, 2025
GreenBar0n
Where is that exactly, and how would I check it? Thanks!
Dec 22, 2025
Nixontheknight
check the main crystal, maybe something's up with it
Dec 22, 2025
GreenBar0n
Compact Macs
Hi all, Really glad to have found this forum recently and specifically the Simasima Repair Guide posted here, much thanks for that! I...
Dec 22, 2025
New LC475 user - Questions on PowerPC upgrades
I've generally found PowerPC upgrades for 68K Macs of questionable value these days. Back in the day they made sense to run software you...
Dec 22, 2025
It is not falsing triggering the auto stop, unless you have about 40 frames of completely clear. This is just the limitations of the...
Dec 22, 2025
It is not a hard number, as it also depends on the grain and detail in your footage, and the rate of change in the footage. The...
Dec 22, 2025
BlueSCSI Toolbox
Mihaip and I got BlueSCSI Toolbox working in DingusPPC and now mihaip has it working in Infinite Mac as a way to get files to a machine...
Dec 22, 2025
