H
hasi
By the way: I use Qp of 16 and it works fine. Sometimes it stops after an unpredictable number of frames. Can be as high as 17`000...
Dec 23, 2025
H
hasi
After scanning varios Kodahchrome films, here are my white balance numbers: 321,176,145. No blue snow and no reddisch faces any more...
Dec 23, 2025
8-bit Boléro (The World's Most Ambitious Chiptune?)
The instruments and the virtuosity are all great, but I love how he does it all in a tux (and even varies his neckwear).
Dec 23, 2025
P
phipli
New LC475 user - Questions on PowerPC upgrades
The 475 and 575 use a chipset derived from the 650 / 800 chipset. They're all technically spec'd up to 40MHz. There are datasheets...
Dec 23, 2025
Interesting, so they used the same ASICs et al as on the 840AV? That was the only 68040/40 machine released. Where did your 475...
Dec 23, 2025
P
phipli
I suspect it isn't what you're thinking, but interestingly @Trash80toG4, only the CPU and PLL aren't rated for 40MHz on the LC 475. I've...
Dec 23, 2025
Either one, not one for overclocking here, so sticking with 25Mhz would be fine, it's the FPU that counts. Q605 was first gen Quadra...
Dec 23, 2025
maikol
Thank you. Good points and suggestions. I have one of those heatsinks lying around and I will put one on before and try the overclock...
Dec 23, 2025
P
phipli
The same version should be available in both places, but I'm more likely to forget to update my website than Macintosh Garden. I would...
Dec 23, 2025
A very special Mac Portable
Indeed, favorite is the god "Finagle" in Niven/Pournelle world building of space faring civilizations. Glad it was appreciated. I'd...
Dec 23, 2025
mac27
iBook G3 Clamshell display replacement failure, a cautionary tale
Well, finally a step back in the right direction. Got the replacement motherboard installed and I have an iBook with operational...
Dec 23, 2025
