GreenBar0n
Hoping the CPU is what's bad. The UE10 DSC was really bad on this SE/30, the voltage line broke and probably four other lines were...
Dec 24, 2025
muse
The scope is the right tool. I also can't see a problem with the waveforms you took, its normal to see some noise in those readings...
Dec 24, 2025
A very special Mac Portable
I like the fact you enjoy that model iMac because it really doesn't get enough love. That metal Arm for the display was and still is so...
Dec 24, 2025
GreenBar0n
I used the DMM to look at the ROM slot pins, they are all over the place in voltage, very few are always stuck at +5.05V, but nearly all...
Dec 24, 2025
jeffburg
Totally! I usually hang out in the G4/G5 section here because those were my high school days. I recently got my dream high school set...
Dec 24, 2025
GreenBar0n
The Reset pin F12 on the CPU is functional, it goes from +5.05V to 0 - 0.80Mv when S1 is pressed. The only Reset pins that were...
Dec 24, 2025
Radius Rocket & SCSI Booster Clones
Replies came as I was going to bed last night, and I'm at work now. Will consider use of RocketShare software later, although it will...
Dec 24, 2025
muse
8-bit Boléro (The World's Most Ambitious Chiptune?)
He has a lot of patience. Can't appreciate enough how long it took him to record and then do the editing, mixing. :)
Dec 24, 2025
I too was a MacUser subscriber since the 1980's. Not quite from the Premier issue, but close! My subscription was rolled into Macworld...
Dec 24, 2025
