Mac84
Thanks! I’ll try a new 3D printed mount - thankfully the issue went away after zooming in and out a few times.
Dec 24, 2025
33K is a tad low for Qp 16. But for stock lens at 16 or 18fps it could be okay.
Dec 24, 2025
P
pff000
ITXPlus: A ITX Sized Macintosh Plus Logicboard Reproduction
@max1zzz the board I got from you is working perfectly and has been fun to set up and play with. Just wanted to share the result, I 3d...
Dec 24, 2025
I don't understand this one. Can you video what is happening?
Dec 24, 2025
I expect your new lens might be pointing to far to one side. When you are reframing to centering, might be using some out-of-range...
Dec 24, 2025
Mac84
Hello @0dan0, FYI I encountered this interesting glitch after I was zooming in and out of the frame, and it is persistent after power...
Dec 24, 2025
Mikm
When I need to adjust the frame while it's recording, I stopped first the recording, select adjust from the menu and on the moment I...
Dec 24, 2025
maikol
New LC475 user - Questions on PowerPC upgrades
OK so I've come across a SIMM that looks like this. There are a total of 32 M5116100A chips. I think those are FastPage Memory? Excuse...
Dec 24, 2025
B
BigBadBiologist
Some resources for Fujitsu FM Towns II UG20
Other
I recently did a refurbishment of a Fujitsu FM Towns II UG20. These are super cool little not-quite-DOS-compatible x86 all-in-one...
Dec 24, 2025
H
hasi
Average bitrate of the scan is 33000 kBit/sec. The enclosed sample scan is stored in HD- Format with a bitrate of 19000kBit/sec. It has...
Dec 24, 2025
GreenBar0n
Hoping the CPU is what's bad. The UE10 DSC was really bad on this SE/30, the voltage line broke and probably four other lines were...
Dec 24, 2025
