GreenBar0n
Macintosh SE/30 Vertical & Horizontal Bars on Display "Simasima" Repair Guide
This guide was the reason I found this site and joined, well done and thank you for this! I wanted to ask about the Reset section, on...
Dec 24, 2025
Nixontheknight
New LC475 user - Questions on PowerPC upgrades
I wonder if this would work in an LC III, it is the same computer save for the CPU
Dec 24, 2025
S
sheider
I've seen this bug, but I didn't bother reporting it because it only happened once and I couldn't repeat it. Anyway, the workaround is...
Dec 24, 2025
This might be a new limitation. It seems it was broken in V7.4 (v7.3 is okay). So two steps forward, one step back. In three weeks no...
Dec 24, 2025
Video is blank here. I only hear the audio. I was able to download to see it.
Dec 24, 2025
P
phipli
This is an LC 475 with a 128MB module fitted : The memory test takes almost exactly 1 minute with this much RAM.
Dec 24, 2025
Mikm
Sure, see the video, I just went from recording mode to Frame adjustment mode and when pushing the < > button(s) the frame on screen...
Dec 24, 2025
P
phipli
No hardware fix needed - these just work up to 128MB with compatible RAM. Yes... but not more than a minute for 68MB. Something isn't...
Dec 24, 2025
P
phipli
I believe so, based on the datasheet. Looks like it is a 64MB SIMM. The LC 475 can take up to a 128MB SIMM, FPM. It should work with...
Dec 24, 2025
