PowerRCP-G3
Day 1: I started editing a video on my Power Mac G5 and have brought out the PowerBook G4 to use whenever the G5 is unavailable. So...
Jan 2, 2026
Identifying this color classic analog mod (640x480 without cutting sense line?)
OK. J19 is cut in half, as you say. That only means the two pins on that part (transistor? something else? You'd need to read its P/N...
Jan 2, 2026
ComputerCompulsive
LOL but that's the part I can't figure out! ;) Oh btw J19 was cut in half on the top of the board so the brown wire only attaches at...
Jan 2, 2026
Here is the horizontally flipped version of your BROWN WIRE photo... And here is the component side (not flipped), perfectly matched...
Jan 2, 2026
speakers
Macintosh II SI capacitor question
Weak or totally absent decoupling caps like C20/C22, may not stop the machine running. In fact, a logic board could work with no...
Jan 2, 2026
ComputerCompulsive
So to clarify im aware the voltage change isn't needed for the color classic board. I was just testing the board as it was after...
Jan 1, 2026
ComputerCompulsive
Jan 1, 2026
There is no reason to boost the voltage to 68.4V like you have when using the stock motherboard. Yes, you can leave it that way by...
Jan 1, 2026
Custom 9.7" Display (iPad 1,2,3) for Apple //c with STL files and build guide [Draft: work in progress]
Apple I/II/III
This is primarily based on the design by @ArjenCNX in this thread. I have made some modifications to the files to support any iPad 1, 2...
Jan 1, 2026
