F
fred1212
reviewed the resource
Apple Service Guide Vol 1
3.00 star(s)
All pages after 25 are blank
Jan 10, 2026
Yep, no apparent damage to the board . . . nope BATTERY BOMB! . . . . . . new project thread started for next year's PPC...
Jan 10, 2026
Time has been limited with everything going on around here. I did manage to get a Netac 120Gb SSD into an Orico drive sled and installed...
Jan 10, 2026
Stock lens resolves about 640x480 for an 8mm frame. Film is about 4000 dpi as the active frame is about 7mm wide (Super8), theoretical...
Jan 10, 2026
That is just case rust, no damage on the motherboard? Almost looks like a battery bomb. I love the Jenga pile from floor to ceiling...
Jan 10, 2026
Wanted to get the spec on the JackHammer in the Radius 81/110. Managed to get the side panel off and pull the card. Meanwhile I found...
Jan 10, 2026
K
klaatu
Can you quantify the improvement with the lens modification? I think I'm inclined to just go with the firmware upgrade and leave the...
Jan 10, 2026
No guide for the case mod, but I've done four now. However, you should begin the hardware modification until the new firmware is...
Jan 10, 2026
GreenBar0n
On page 24 (PDF pg.27) of the Simasima Repair Guide it says a 10L Ultrasonic cleaner is the bare minimum to fit the SE/30 logic board...
Jan 10, 2026
videodoctor
So much excellent information on this forum and thread! @0dan0 , I saw your posts related to lens modification here...
Jan 10, 2026
Attached to the Type D installer firmware (.BIN) and uncompressed binary (.RBN, use this in Ghidra and editing) in a zip. This is...
Jan 10, 2026
