muse
I don't think Computer Chronicles aired in my part of Australia. According to google, it aired in Brisbane on Briz 31 but I never heard...
Jan 11, 2026
SuperSVGA
Macintosh Portable SLIM cards
They do work just fine since the entire driver is in ROM: Getting it in the Powerbook 100 would be tricky, since you need both...
Jan 11, 2026
RetroViator
Mac IIsi Repairathon
The Dreaded Power Supplies Knowing how bad the IIsi power supplies are (due to leaky SMD caps on the soft power daughter board and leaky...
Jan 11, 2026
Macintosh Portable
Digging around in the ROM and source code, Apple originally planned to include removable disk cards on the Macintosh Portable. This...
Jan 11, 2026
mac27
Power Mac G4 Quicksilver main case fan replacement
Thanks, I'd assumed NOS OEM parts wouldn't be available, but nope. I picked up one of these lots and will try that out instead.
Jan 11, 2026
G
greenmachine
Aftermarket fans are really hit or miss with noise. Noctua is always a solid choice if you don't mind the odd color scheme, and they...
Jan 11, 2026
mac27
PowerMac G4, iMac G4 & eMac
Just documenting a quick little repair/maintenance item I took care of today. The main case fan in my Quicksilver was nice and quiet...
Jan 11, 2026
GreenBar0n
It took the Vevor 10L Ultrasonic nearly 3 hours to heat the water to 65°C, had to bring the unit indoors because it was 65°F outside and...
Jan 11, 2026
Budget Oscilloscope Recommendation?
That RIGOL DHO814 vid had me drooling, but I might need to spend a bit on one of these entry level units to get the hang of it? My...
Jan 11, 2026
B
BFEXTU
Apple IIe + ESP32 SoftCard Setup - Working!
Apple I/II/III
My ESP32 SoftCard arrived and I have been having some fun with it! CVT, the creator (located in Bulgaria), has done some incredible work...
Jan 11, 2026
Yes, this has all been explained in detail in the original thread (hours for reading for you.) This image is from Feb 2025...
Jan 11, 2026
Day 11 and after booting up like a champ the first time I fired it up out in the living room on day 8, it returns to the glorious state...
Jan 11, 2026
K
klaatu
I want to make sure I understand this. Are you saying that the 8mm lens is capturing a much larger area than it needs to, and that...
Jan 11, 2026
