community projects
, join
GlobalTalk
, and have fun!
colinlm
Introducing BurgerDisk, a daisy-chainable Smartport hard drive
Apple I/II/III
BurgerDisk is a Smartport hard drive for the Apple II. Its main unique feature is that it is daisy-chainable. As all Smartport SD-based...
Jan 12, 2026
The existing USB port has a different function, it is not connecting to the debug interface that's on the main board. I just added...
Jan 12, 2026
videodoctor
As much as I do not want to add a serial port to the device, it seems prudent of course! @0dan0 , can you recommend the UART USB serial...
Jan 12, 2026
B
Brutus75
Macintosh IIfx questions
Macintosh II
Hi Guys, I recently acquired a Macintosh IIfx in really good shape (no exploding batteries and all the caps are the original tantalums...
Jan 12, 2026
Thank you. I have attempted to get an H2825 model from eBay, but many sellers will not respond to enquires about serial number (even ask...
Jan 12, 2026
If you can add the serial port, then you can dump the firmware, this must be before any update attempts (if you want exactly what your...
Jan 12, 2026
lrdgreen89
I got this off eBay from a user who apparently bought it new, used it once for his batch of reels. It just arrived today. My...
Jan 12, 2026
B
Brutus75
Mac SE with sad Mac code 00000001 0000FFFF
I managed to pick up some replacement ROMS from a Japanese site...
Jan 12, 2026
videodoctor
@0dan0 , hmm.... I have the H2825 unit, not the D2825. Should I still try the Type B firmware on this unit, or is that already known to...
Jan 12, 2026
Yes, that would appear to be type D. Through which seller do you buy this?
Jan 12, 2026
lrdgreen89
Hello! Following Mac84's lookup tool instruction, I'm sharing my SN which appears to need firmware D? Reels SN: H2825148BK00356...
Jan 12, 2026
iBookSpeedster88
I noticed that, for some reason, people on the MacRumors forums insist on continuing to use, or even set up for the first time...
Jan 12, 2026
T
Tony
Looked over the spec sheet on the AR0330 and it uses a Bayer filter on 3.5million photosites (RGGB) that are masticated / demosaiced...
Jan 12, 2026
