Board Nominations
here.
community projects
, join
GlobalTalk
, and have fun!
GreenBar0n
SE/30 #1 logic board now works also!! Turns out my simasima problem was missing D(1) all along. I had replaced my CPU socket to aid in...
Jan 12, 2026
misterg33
PowerComputing PowerCenter Pro Restore CD
Looks like they might have made some changes. Haven't run into the 403 error in a couple of weeks! 🤞
Jan 12, 2026
It is probably okay. I didn't follow the guide exactly, and used whatever I had around.
Jan 12, 2026
videodoctor
@0dan0, which gauge wire did you use for your UART connector to the Reelz board? The tutorial mentions 34 AWG. Is 22 AWG too thick for...
Jan 12, 2026
colinlm
Introducing BurgerDisk, a daisy-chainable Smartport hard drive
Apple I/II/III
BurgerDisk is a Smartport hard drive for the Apple II. Its main unique feature is that it is daisy-chainable. As all Smartport SD-based...
Jan 12, 2026
The existing USB port has a different function, it is not connecting to the debug interface that's on the main board. I just added...
Jan 12, 2026
videodoctor
As much as I do not want to add a serial port to the device, it seems prudent of course! @0dan0 , can you recommend the UART USB serial...
Jan 12, 2026
B
Brutus75
Macintosh IIfx questions
Macintosh II
Hi Guys, I recently acquired a Macintosh IIfx in really good shape (no exploding batteries and all the caps are the original tantalums...
Jan 12, 2026
Thank you. I have attempted to get an H2825 model from eBay, but many sellers will not respond to enquires about serial number (even ask...
Jan 12, 2026
If you can add the serial port, then you can dump the firmware, this must be before any update attempts (if you want exactly what your...
Jan 12, 2026
lrdgreen89
I got this off eBay from a user who apparently bought it new, used it once for his batch of reels. It just arrived today. My...
Jan 12, 2026
B
Brutus75
Mac SE with sad Mac code 00000001 0000FFFF
I managed to pick up some replacement ROMS from a Japanese site...
Jan 12, 2026
videodoctor
@0dan0 , hmm.... I have the H2825 unit, not the D2825. Should I still try the Type B firmware on this unit, or is that already known to...
Jan 12, 2026
