GreenBar0n
Compact Macs
Specifically I'm looking to fix the screw hole where the CRT is grounded to. My front case/bezel arrived with the CRT ground hole in a...
Tuesday at 5:07 AM
GreenBar0n
It's not that UE8 bodge wire causing the weird screen distortion in the video above, I just tried SE/30 #2's LB and it's doing the exact...
Tuesday at 4:51 AM
Deano
Hello everyone, Just before the New Year, I received the components necessary for upgrading the lens on my Type C system. Since then...
Tuesday at 4:33 AM
RetroViator
Mac IIsi Repairathon
What's next... I tested each of the five functional boards with my snazzy TechStep built by @max1zzz. It confirmed that Delta and Echo...
Tuesday at 3:55 AM
GreenBar0n
I do have the green UV mask stuff, will put that on the spots I scraped, thanks! Here's my UE8 bodge wire from Pin 10, this goes to...
Tuesday at 3:11 AM
Wouldn't this post be more effective over on MR? - The forum where the thread is actually located with the folks using/talking about it...
Tuesday at 2:50 AM
muse
Good effort. Just remember that any exposed copper needs lacquer applied to it to prevent from further damage. You can use clear nail...
Tuesday at 2:47 AM
GreenBar0n
The ultrasonic cleaning with the correct Elma TEC Clean A1, should've neutralized and removed any further corrosion. I already have a...
Tuesday at 1:17 AM
Nixontheknight
Congrats on reviving an SE/30! If the board with the bodge ever gets worse, try looking into the SE/30 reloaded board
Tuesday at 1:14 AM
GreenBar0n
Thanks so much guys! An interesting thing to note about the fix, is that I checked the Data and Address Matrix's, multiple times, it...
Tuesday at 1:11 AM
