Board Nominations
here.
community projects
, join
GlobalTalk
, and have fun!
PowerRCP-G3
Day 12: While my DVD continued to process, I played around with two emulators and watched some YouTube to pass the time.
Jan 13, 2026
wicknix
Just chiming in. 1) Yes both remixes are now both quite old. Still newer and slightly more secure than 10.5.8 Leopard (including...
Jan 13, 2026
jmacz
Macintosh IIfx questions
For the speaker, someone had mentioned these which seem to be a direct match for the speakers used in the Mac II. I believe the IIfx is...
Jan 13, 2026
GreenBar0n
Compact Macs
Specifically I'm looking to fix the screw hole where the CRT is grounded to. My front case/bezel arrived with the CRT ground hole in a...
Jan 13, 2026
GreenBar0n
It's not that UE8 bodge wire causing the weird screen distortion in the video above, I just tried SE/30 #2's LB and it's doing the exact...
Jan 13, 2026
Deano
Hello everyone, Just before the New Year, I received the components necessary for upgrading the lens on my Type C system. Since then...
Jan 13, 2026
RetroViator
Mac IIsi Repairathon
What's next... I tested each of the five functional boards with my snazzy TechStep built by @max1zzz. It confirmed that Delta and Echo...
Jan 13, 2026
GreenBar0n
I do have the green UV mask stuff, will put that on the spots I scraped, thanks! Here's my UE8 bodge wire from Pin 10, this goes to...
Jan 13, 2026
Wouldn't this post be more effective over on MR? - The forum where the thread is actually located with the folks using/talking about it...
Jan 13, 2026
muse
Good effort. Just remember that any exposed copper needs lacquer applied to it to prevent from further damage. You can use clear nail...
Jan 13, 2026
