clicking here
B
BFEXTU
Building A/UX Device Drivers
I finally got a new scanner! Unfortunately, my other one broke some time ago. So, I should now be able to finish scanning the A/UX docs...
Jan 13, 2026
GreenBar0n
I would do that with metal but plastic is easier to fix. I won't say the following is the best way to fix a stripped case thread but I...
Jan 13, 2026
P
PopeLeo
Apple 15 inch Studio Display (M4551) missing a power supply
Thanks, I couldn't find that exact one, but I measured the barrel jack on the monitor and it seems to be a standard 5.5mm x 2.5mm jack...
Jan 13, 2026
Neat Pata/Sata card. I've never seen one before. I have a Visiontek 7000 pci in my B&W running Tiger. Ive not played with that ATI...
Jan 13, 2026
LOL! Yep, it's hilarious, buddy. But I think I've noodled it out. Having VGA hooked up to the the 4:5 panel and DVI running through...
Jan 13, 2026
Macintosh IIfx questions
That's a reasonable conclusion and would not be unusual. However, I've noticed that the IIfx can be very fiddly with memory slots in...
Jan 13, 2026
sunvalleylaw
Starting my Compact Mac Vintage Journey with this SE modded to SE/30 project.
This should get here Thursday!
Jan 13, 2026
sunvalleylaw
New to Me - Power Macintosh G3 Beige Desktop – 266MHz – 224MB RAM – 6GB HDD – Mac OS 9, project
Did some futzing and figured out prior owner installed an ATI Rage 128 with a VGA port from a newer G3. Which was good because I chose...
Jan 13, 2026
I
indibil
Macintosh LCII failure
I did another test. I was testing it with a dead battery (0.5V), and I tested it with a new battery (3.5V), and with both I get the same...
Jan 13, 2026
