clicking here
videodoctor
@0dan0 , do you have any pictures of where you soldered wire to on the UART board?
Jan 13, 2026
PowerBook 100 & 170 owners
I picked up what I thought was the low-power + EMI filter Portable (or PowerBook) mouse. Indeed, it has the extra long connector. The...
Jan 13, 2026
Good tip, that' about like using toothpicks in a stripped screwhole in a wooden cabinet door. But without the wood glue.
Jan 13, 2026
B
BFEXTU
Building A/UX Device Drivers
I finally got a new scanner! Unfortunately, my other one broke some time ago. So, I should now be able to finish scanning the A/UX docs...
Jan 13, 2026
GreenBar0n
I would do that with metal but plastic is easier to fix. I won't say the following is the best way to fix a stripped case thread but I...
Jan 13, 2026
P
PopeLeo
Apple 15 inch Studio Display (M4551) missing a power supply
Thanks, I couldn't find that exact one, but I measured the barrel jack on the monitor and it seems to be a standard 5.5mm x 2.5mm jack...
Jan 13, 2026
Neat Pata/Sata card. I've never seen one before. I have a Visiontek 7000 pci in my B&W running Tiger. Ive not played with that ATI...
Jan 13, 2026
LOL! Yep, it's hilarious, buddy. But I think I've noodled it out. Having VGA hooked up to the the 4:5 panel and DVI running through...
Jan 13, 2026
Macintosh IIfx questions
That's a reasonable conclusion and would not be unusual. However, I've noticed that the IIfx can be very fiddly with memory slots in...
Jan 13, 2026
