Board Nominations
here.
community projects
, join
GlobalTalk
, and have fun!
Just short RST to GND, and TX on the main board goes to TX1 on the Nano, same for RX to RX0 and GND to GND.
Jan 13, 2026
Great post. I have stopped using the 3mm F-stop change, while it does make focusing easier (not required), and it does add some...
Jan 13, 2026
This Does Not Compute
Looking at it from another angle: You don't have to use that specific standoff for the grounding lead, any of them will work.
Jan 13, 2026
videodoctor
@0dan0 , do you have any pictures of where you soldered wire to on the UART board?
Jan 13, 2026
PowerBook 100 & 170 owners
I picked up what I thought was the low-power + EMI filter Portable (or PowerBook) mouse. Indeed, it has the extra long connector. The...
Jan 13, 2026
Good tip, that' about like using toothpicks in a stripped screwhole in a wooden cabinet door. But without the wood glue.
Jan 13, 2026
B
BFEXTU
Building A/UX Device Drivers
I finally got a new scanner! Unfortunately, my other one broke some time ago. So, I should now be able to finish scanning the A/UX docs...
Jan 13, 2026
GreenBar0n
I would do that with metal but plastic is easier to fix. I won't say the following is the best way to fix a stripped case thread but I...
Jan 13, 2026
P
PopeLeo
Apple 15 inch Studio Display (M4551) missing a power supply
Thanks, I couldn't find that exact one, but I measured the barrel jack on the monitor and it seems to be a standard 5.5mm x 2.5mm jack...
Jan 13, 2026
