Board Nominations
here.
community projects
, join
GlobalTalk
, and have fun!
MicroCoreLabs
MCL68+ A Motorola 68000 drop-in emulator
Update on this project: I fixed the remaining issues with the 68000 opcodes using Tom Harte's test suite and got some pleasant results...
Jan 15, 2026
I
indibil
Macintosh LCII failure
1uF, like the original.
Jan 15, 2026
I
indibil
Okay, I'm going to do a thorough cleaning. I've already done a little, but it doesn't seem to be enough. As I mentioned in the first...
Jan 15, 2026
Here is the cap kit from Console 5 for LC II / 400. $7 is pretty cheap.
Jan 15, 2026
I
iigs123
is the capacitor by UA10, C22 I think, the correct type? Why not get a cap kit from somewhere like Console5 and redo everything? here is...
Jan 15, 2026
Based on these photos, I am going to suggest a thorough cleaning. Completely remove the motherboard and soak it in IPA and gently scrub...
Jan 15, 2026
I
indibil
I am attaching photos that I was able to take yesterday. As for the PSU, I have tested both the repaired one and the one I use in a...
Jan 15, 2026
victor.muc
Fixing the floppy drive of a Macintosh SE without dying
Thank you so much! I definitely will be cautious.
Jan 15, 2026
GreenBar0n
You'll be fine, you sound cautious and that's enough to keep you above ground :). Pretty sure the discharge procedure of the CRT is...
Jan 15, 2026
victor.muc
Compact Macs
Hey everyone, I’ve repaired a lot of Apple hardware over the years (PowerBooks, iBooks, iMacs, Intel Macs, etc.). Over the last couple...
Jan 15, 2026
