clicking here
GreenBar0n
Got the thumbtacks today, had to drill the hole out in the 3D printed adapter, could be because I printed it at .12 instead of .20 so it...
Jan 20, 2026
LC 520 with flaky CRT
Just to double check as folks often don't know this but the LC 520's rear power switch being switched on will not start the Mac, you...
Jan 20, 2026
charkes
Macintosh LC & Performa
Hello, I just got an LC 520 that's been in storage for years. I removed the battery (no signs of any damage) and cleaned the logic...
Jan 20, 2026
mac27
Replacement MacEffects inner bezel for iMac G3
PowerMac G3 & iMac G3
Well my gray iMac bezel arrived recently - woohoo! I'll be taking on this project within the next week or two ... and will be recording...
Jan 19, 2026
O
Oelmuvun
PowerMac G4 Opening Lever Creaking - Can It Be Silenced?
WD-40 isn't a lubricant. 3M silicone grease, and you won't need much.
Jan 19, 2026
Yes. Everything is exactly the same in each of the four tests except the Analog Board.
Jan 19, 2026
B
BFEXTU
SuperMac Enhance Board Memory Upgrade Information
I found 2 old Enhance boards. One of them is missing the slotted PAL (E4000/E6000), but the other one has an E4000 v2 PAL in that...
Jan 19, 2026
GreenBar0n
It's amazing to me that there is not a dedicated tool for such a task. I guess it's an adjustment that's rarely performed but there had...
Jan 19, 2026
S. Pupp
As far as the correct tool for the horizontal adjustment is concerned, I made a mold of an Allen wrench using silicone putty, poured in...
Jan 19, 2026
GreenBar0n
Where to get a TDA1170 chip?
The only way you could go wrong there is if the chips are fakes - but if you checked out the sellers feedback and he has no history of...
Jan 19, 2026
Nixontheknight
try 3-in-1 oil or something like that
Jan 19, 2026
