community projects
, join
GlobalTalk
, and have fun!
Day 19 G5 Quad 2.5GHz again. I started out with no boot chime and no video. Overtemp? Well I put some water in a short tube and...
Jan 20, 2026
charkes
LC 520 with flaky CRT
Yes, I've used the keyboard's soft power to start it. (Thank you for checking.) The rear fan spins, the lights come on, the chime sounds...
Jan 20, 2026
Macintosh Portable
The Macintosh Portable has a certain cachet. It possesses an exquisite keyboard, a crisp screen, and a complete set of ports and slots...
Jan 20, 2026
GreenBar0n
Got the thumbtacks today, had to drill the hole out in the 3D printed adapter, could be because I printed it at .12 instead of .20 so it...
Jan 20, 2026
Just to double check as folks often don't know this but the LC 520's rear power switch being switched on will not start the Mac, you...
Jan 20, 2026
charkes
Macintosh LC & Performa
Hello, I just got an LC 520 that's been in storage for years. I removed the battery (no signs of any damage) and cleaned the logic...
Jan 20, 2026
mac27
Replacement MacEffects inner bezel for iMac G3
PowerPC G3, G4 & G5 (New World ROM)
Well my gray iMac bezel arrived recently - woohoo! I'll be taking on this project within the next week or two ... and will be recording...
Jan 19, 2026
O
Oelmuvun
PowerMac G4 Opening Lever Creaking - Can It Be Silenced?
WD-40 isn't a lubricant. 3M silicone grease, and you won't need much.
Jan 19, 2026
Yes. Everything is exactly the same in each of the four tests except the Analog Board.
Jan 19, 2026
B
BFEXTU
SuperMac Enhance Board Memory Upgrade Information
I found 2 old Enhance boards. One of them is missing the slotted PAL (E4000/E6000), but the other one has an E4000 v2 PAL in that...
Jan 19, 2026
GreenBar0n
It's amazing to me that there is not a dedicated tool for such a task. I guess it's an adjustment that's rarely performed but there had...
Jan 19, 2026
