clicking here
Macintosh Portable: "pop" noise every 10s from Speaker & Headphones
In System 7.0.1 the patch is located in the System file at 'lpch' #8 @$1206. In System 7.1, the patch is located in the System file at...
Jan 20, 2026
caver01
Thanks for sharing your journey! It is inspiring to see another example of someone taking on an SE/30 restoration project. Having been...
Jan 20, 2026
charkes
LC 520 with flaky CRT
Yeah, I'm not getting a chime anymore. I've removed the back shell and carefully set it back up. When I hit the soft power there's the...
Jan 20, 2026
This is base version (type D) that has creates code space by resizing and removing one of the JPEGs in the firmware. Can you confirm it...
Jan 20, 2026
JeffC
Pulled FPU from an Asante… can you do anything with it?
You can use a 68882 in place of a 68881, for instance in a Mac II, as long as both chips are the same package (PGA).
Jan 20, 2026
My next guess would be the logic board needs a recap...
Jan 20, 2026
charkes
Not any change. Pop of the speakers coming on, fan spins, chime *not* happening this time. Hmm.
Jan 20, 2026
RetroViator
Mac IIsi Repairathon
Alpha is A-Okay After spending time on Bravo's audio problems, I decided to check out Alpha's speaker problem while the subject was...
Jan 20, 2026
Day 19 G5 Quad 2.5GHz again. I started out with no boot chime and no video. Overtemp? Well I put some water in a short tube and...
Jan 20, 2026
charkes
Yes, I've used the keyboard's soft power to start it. (Thank you for checking.) The rear fan spins, the lights come on, the chime sounds...
Jan 20, 2026
