clicking here
Macintosh Portable: "pop" noise every 10s from Speaker & Headphones
Thank you, David, I will try your disk image on my FloppyEMU tonight after work. Desktop Manager has nothing to do with it because I...
Jan 21, 2026
I do use the Desktop Mgr extension (to not have the desktop rebuilt when switching between 6 and 7). I don't think that is a cause. But...
Jan 21, 2026
I reduced my system down to a floppy disk and verified that it sleeps when booted from a FloppyEMU. The .dsk is attached. It is not...
Jan 21, 2026
I have a MacEffects RAM card which I have artificially limited to 5MB by way of not running the required jumper. (Limited RAM is painful...
Jan 21, 2026
I am rewatching your video to see if there is something obviously different about yours.
Jan 21, 2026
ZuluSCSI Compact RP2040 Lead acid. Battery 50-60% full based on battery desk accessory. No modem installed. October 2023 Androda...
Jan 21, 2026
videodoctor
Device: Kodak Reels Type D (H-series, Serial: H2825148BK...) Achievement: 1600x1200 output resolution working on D variant hardware...
Jan 21, 2026
Do you have a BlueSCSI v2 or spinner drive? Do you have a lead acid battery or Battery Eliminator? My BSv2 is resistor modded to avoid...
Jan 21, 2026
Powerbase over at the MLA said he understands this to be standard behavior. Looks to me to be behaving like unclean Macs running without...
Jan 21, 2026
I can confirm the same. Backlit Portable, PowerBook 7.1 control panel, AppleTalk off, power adapter unplugged, maximum conservation...
Jan 21, 2026
