clicking here
colinlm
Introducing BurgerDisk, a daisy-chainable Smartport hard drive
I moved the SD slot in the front, this is more practical. Added a way to stick in a logo if you have one lying around.
Jan 21, 2026
Macintosh Portable: "pop" noise every 10s from Speaker & Headphones
BTW, I checked and found that this forum already allows moof and dc42, so it makes no sense to disallow support of dsk, so I added it...
Jan 21, 2026
Thank you, David, I will try your disk image on my FloppyEMU tonight after work. Desktop Manager has nothing to do with it because I...
Jan 21, 2026
I do use the Desktop Mgr extension (to not have the desktop rebuilt when switching between 6 and 7). I don't think that is a cause. But...
Jan 21, 2026
I reduced my system down to a floppy disk and verified that it sleeps when booted from a FloppyEMU. The .dsk is attached. It is not...
Jan 21, 2026
I have a MacEffects RAM card which I have artificially limited to 5MB by way of not running the required jumper. (Limited RAM is painful...
Jan 21, 2026
I am rewatching your video to see if there is something obviously different about yours.
Jan 21, 2026
ZuluSCSI Compact RP2040 Lead acid. Battery 50-60% full based on battery desk accessory. No modem installed. October 2023 Androda...
Jan 21, 2026
videodoctor
Device: Kodak Reels Type D (H-series, Serial: H2825148BK...) Achievement: 1600x1200 output resolution working on D variant hardware...
Jan 21, 2026
Do you have a BlueSCSI v2 or spinner drive? Do you have a lead acid battery or Battery Eliminator? My BSv2 is resistor modded to avoid...
Jan 21, 2026
