community projects
, join
GlobalTalk
, and have fun!
warmech
Radius Monochrome (Greyscale) Pivot Capacitor List
CRT
Following in the footsteps of @Elemenoh, I have disassembled a monochrome/greyscale Radius Pivot (model 0361 - apparently identical to...
Jan 21, 2026
A
ArjenCNX
Test Jig for CC analog/digital boards
I sure can, so i had a LC575 computer, damaged in shipment due to very brittle plastics. I could not repair it, so i decided to make a...
Jan 21, 2026
colinlm
Introducing BurgerDisk, a daisy-chainable Smartport hard drive
I moved the SD slot in the front, this is more practical. Added a way to stick in a logo if you have one lying around.
Jan 21, 2026
Macintosh Portable: "pop" noise every 10s from Speaker & Headphones
BTW, I checked and found that this forum already allows moof and dc42, so it makes no sense to disallow support of dsk, so I added it...
Jan 21, 2026
Thank you, David, I will try your disk image on my FloppyEMU tonight after work. Desktop Manager has nothing to do with it because I...
Jan 21, 2026
I do use the Desktop Mgr extension (to not have the desktop rebuilt when switching between 6 and 7). I don't think that is a cause. But...
Jan 21, 2026
I reduced my system down to a floppy disk and verified that it sleeps when booted from a FloppyEMU. The .dsk is attached. It is not...
Jan 21, 2026
I have a MacEffects RAM card which I have artificially limited to 5MB by way of not running the required jumper. (Limited RAM is painful...
Jan 21, 2026
I am rewatching your video to see if there is something obviously different about yours.
Jan 21, 2026
ZuluSCSI Compact RP2040 Lead acid. Battery 50-60% full based on battery desk accessory. No modem installed. October 2023 Androda...
Jan 21, 2026
