clicking here
PCjr picture going a bit funny
Those monitors are also subject to bad solder joins. I had something similar happen with mine. The length of time makes me wonder about...
Jan 21, 2026
Pulled FPU from an Asante… can you do anything with it?
This is a bit of an oversimplification, but an easy discriminator is QFPs have pins on the sides and PGAs have pins underneath. The good...
Jan 21, 2026
calcmandan
Any interest in Palm Pilots?
I've been using the same Tungsten T5 since original purchase in 2004 (22 years in September). The only thing I've replaced is the WiFi...
Jan 21, 2026
Nixontheknight
it's a QFP 882, so you can't use that in an 881 socket
Jan 21, 2026
N
NJRoadfan
Kinda stumbled across a utility suite that came with the Columbia AppleTalk Package...
Jan 21, 2026
As I don't have a Type D, I don't know what they have changed. On all three previous models the LCD buffer was at 0x81821180. This is...
Jan 21, 2026
videodoctor
I've ported (what I believe are) the core improvements from 0dan0's Type C firmware to Type D hardware. The device now runs 1600x1200 @...
Jan 21, 2026
Portable and PowerBook 100 Technical Note: PRAM, Backlight, and ROM Diff
Macintosh Portable
As I have been looking at the Macintosh Portable in more depth. I've run across a couple of pieces of technical information that may be...
Jan 21, 2026
Macintosh Portable: "pop" noise every 10s from Speaker & Headphones
That's good news. At least it isn't a hardware issue.
Jan 21, 2026
PowerRCP-G3
Here is a recap of what happened yesterday. Day 21: The power went back on and I got to use the iMac G5 again! It was so good to be...
Jan 21, 2026
