clicking here
P
phipli
Marchintosh 2024: Overclocking a Centris 650
If you're aiming for 40MHz, there are much easier ways to do it - plus you can use 40MHz timings, so that the serial ports etc keep...
Jan 23, 2026
L
larryc39
Yeah those letters didn't really catch my eye in the model and were obscured in my print. I was aware of the three heights tho.
Jan 23, 2026
videodoctor
@0dan0 , were you able to see the reelType value in the D.BIN dump I provided? I've finally got a hook calling into your hist.c code...
Jan 23, 2026
chuck.dubuque
Tips for upgrading my Lisa's MacWorks install from System 4.1 to System 6?
IIRC there are 3 versions of MacWorks: XL, Plus, and Plus II. Plus gets you to system 6. Plus II all the way to 7. You should be able to...
Jan 23, 2026
S. Pupp
CRT compatibility
I once put my SE/30 project on hold for a full decade after spending a day fiddling with the magnets. I valued my sanity, and was at...
Jan 23, 2026
PowerRCP-G3
Here is a recap of what happened on Day 22 Day 22: After I got the IDE to SD card adapter to work, I then tested some emulators to see...
Jan 23, 2026
S
sheider
Yes, notice the "T" and "B" lettering that @0dan0 helpfully included in his design. Also, if you have trouble focusing with the bottom...
Jan 23, 2026
L
larryc39
Wait, so then you're saying the piece with the grooves in it, the larger non-size-adjustable piece goes on top and the smaller one of...
Jan 23, 2026
Huxley
Lisa & Macintosh XL
I'm deep into the process of getting my 'new' Lisa 2/10 setup the way I want. I was able to use my Floppy Emu to install Lisa OS and...
Jan 23, 2026
The undercut is to clear the surface mount components on the other side of the sensorboard. Yes it's a tad harder to print because of...
Jan 23, 2026
lockjaw8y9
yes, but you likely need to do the resistor mod to ensure that serial ports remain functional.
Jan 23, 2026
Arbystpossum
My cat-pee G4 kept Kernal Panicking, and I couldn't figure out why. I kept looking at the KP log, and it kept saying something like "I...
Jan 23, 2026
