community projects
, join
GlobalTalk
, and have fun!
Reel type must be at 0x80340000 Looking at D.BIN (very helpful) the Type D NVM is at 0x80E0ADA4, not what you had suggested. This is...
Jan 23, 2026
P
phipli
Marchintosh 2024: Overclocking a Centris 650
If you're aiming for 40MHz, there are much easier ways to do it - plus you can use 40MHz timings, so that the serial ports etc keep...
Jan 23, 2026
L
larryc39
Yeah those letters didn't really catch my eye in the model and were obscured in my print. I was aware of the three heights tho.
Jan 23, 2026
videodoctor
@0dan0 , were you able to see the reelType value in the D.BIN dump I provided? I've finally got a hook calling into your hist.c code...
Jan 23, 2026
chuck.dubuque
Tips for upgrading my Lisa's MacWorks install from System 4.1 to System 6?
IIRC there are 3 versions of MacWorks: XL, Plus, and Plus II. Plus gets you to system 6. Plus II all the way to 7. You should be able to...
Jan 23, 2026
S. Pupp
CRT compatibility
I once put my SE/30 project on hold for a full decade after spending a day fiddling with the magnets. I valued my sanity, and was at...
Jan 23, 2026
PowerRCP-G3
Here is a recap of what happened on Day 22 Day 22: After I got the IDE to SD card adapter to work, I then tested some emulators to see...
Jan 23, 2026
S
sheider
Yes, notice the "T" and "B" lettering that @0dan0 helpfully included in his design. Also, if you have trouble focusing with the bottom...
Jan 23, 2026
L
larryc39
Wait, so then you're saying the piece with the grooves in it, the larger non-size-adjustable piece goes on top and the smaller one of...
Jan 23, 2026
Huxley
Lisa & Macintosh XL
I'm deep into the process of getting my 'new' Lisa 2/10 setup the way I want. I was able to use my Floppy Emu to install Lisa OS and...
Jan 23, 2026
