clicking here
I
indibil
Macintosh LCII failure
Hi. I have some news :). Since I couldn't get it to work, I cleaned it with a product that has helped me revive old circuits many...
Jan 24, 2026
Classic 8mm is 16fps. Most Super8 is 18fps. Best not to mix as video files do support changing frame rates. If you have to mix, then...
Jan 24, 2026
You will need both hist.c and manwb.c built. But I expect there are a lot other things to fix first. You should be using all the same...
Jan 24, 2026
F
Federico
Hi guys, I have some newbie questions about post-scanning enhancement of the footage. I'm using (using is an overstatement) DaVinci but...
Jan 24, 2026
A
AlpineRaven
6100/66 DOS Compatible
yes and Quadra 700 you will need to modify the case lid & it will need an adapter to reach the I/O ports (its about 3.5" too short) to...
Jan 24, 2026
videodoctor
Thanks, @0dan0! I confirmed that the button address is correct at 0xA0E8b7d0 by seeing 01 for up arrow and 02 for down arrow. The ISO...
Jan 24, 2026
jojo2k
Snazzy Weather - a snazzier weather app for classic Mac OS
Software
Hey what's up, I uploaded a proof of concept type of version of my new Classic Mac OS app SNAZZY WEATHER to my website. Just gets super...
Jan 24, 2026
I updated my type-D firmware with the above code changes. This has not merge in your other patches. So you should just grab bytes...
Jan 24, 2026
GreenBar0n
I have (4) Sony CR-44 PSU's here, (3) recapped and (1) stock but barely used. I'll get some voltage readings this weekend from all of...
Jan 24, 2026
D
davidsmall
Reverse Engineer the Spectre GCR?
Guys, I don't have Spectre GCR schematics or code anymore. There's a D to A converter that sets a voltage controlled oscillator to...
Jan 24, 2026
Reel type must be at 0x80340000 Looking at D.BIN (very helpful) the Type D NVM is at 0x80E0ADA4, not what you had suggested. This is...
Jan 23, 2026
