Board Nominations
here.
community projects
, join
GlobalTalk
, and have fun!
PowerRCP-G3
Here is a recap of what happened yesterday. Day 23: I decided to test out sixtyforce on different PowerPC Macs to see which one would...
Jan 24, 2026
6100/66 DOS Compatible
It doesn't appear a 605 would support the card. At the very least, the opening for a network card isn't large enough for the card...
Jan 24, 2026
Finally - A NeXT Computer (Cube)
I want to, but I'm having some sever performance problems. It's way slower than my NeXT Station, which is the same 25MHz 040... I'm...
Jan 24, 2026
I
indibil
Macintosh LCII failure
Hi. I have some news :). Since I couldn't get it to work, I cleaned it with a product that has helped me revive old circuits many...
Jan 24, 2026
Classic 8mm is 16fps. Most Super8 is 18fps. Best not to mix as video files do support changing frame rates. If you have to mix, then...
Jan 24, 2026
You will need both hist.c and manwb.c built. But I expect there are a lot other things to fix first. You should be using all the same...
Jan 24, 2026
F
Federico
Hi guys, I have some newbie questions about post-scanning enhancement of the footage. I'm using (using is an overstatement) DaVinci but...
Jan 24, 2026
A
AlpineRaven
yes and Quadra 700 you will need to modify the case lid & it will need an adapter to reach the I/O ports (its about 3.5" too short) to...
Jan 24, 2026
videodoctor
Thanks, @0dan0! I confirmed that the button address is correct at 0xA0E8b7d0 by seeing 01 for up arrow and 02 for down arrow. The ISO...
Jan 24, 2026
