clicking here
Any interest in Palm Pilots?
Separate URL: https://retro.tinkerdifferent.com/
Jan 24, 2026
videodoctor
As I continue work to find the AE hook to run 0dan0's custom code, I wanted to share my current bash script to update 0dan0's freed up...
Jan 24, 2026
videodoctor
I've done a lot of video compression with my professional work, and I use ffmpeg regularly. YouTube is going to recompress anything you...
Jan 24, 2026
Finally - A NeXT Computer (Cube)
So, I just recapped the logic board (it looked like someone had recapped, but the surface mount caps were poorly done, and I wanted to...
Jan 24, 2026
I
indibil
Macintosh LCII failure
I'm updating my previous post, as I didn't have much time yesterday and wasn't fully aware of everything. Today I tried a "modern" PSU...
Jan 24, 2026
PowerRCP-G3
Here is a recap of what happened yesterday. Day 23: I decided to test out sixtyforce on different PowerPC Macs to see which one would...
Jan 24, 2026
6100/66 DOS Compatible
It doesn't appear a 605 would support the card. At the very least, the opening for a network card isn't large enough for the card...
Jan 24, 2026
I want to, but I'm having some sever performance problems. It's way slower than my NeXT Station, which is the same 25MHz 040... I'm...
Jan 24, 2026
I
indibil
Hi. I have some news :). Since I couldn't get it to work, I cleaned it with a product that has helped me revive old circuits many...
Jan 24, 2026
Classic 8mm is 16fps. Most Super8 is 18fps. Best not to mix as video files do support changing frame rates. If you have to mix, then...
Jan 24, 2026
