community projects
, join
GlobalTalk
, and have fun!
The code dev stuff could scare some away, but I always ported my findings in the main thread, just in case someone can learn from it...
Jan 24, 2026
videodoctor
Thanks 0dan0! I ran that mem command, and the motor did not stop. To be clear, the BIN you provided is your code update for the motor...
Jan 24, 2026
For recent US purchasers from Amazon, what serial numbers are you getting? H2825, D2825 or something else?
Jan 24, 2026
Yes, you can make Linux versions, I could potential use that too. Here is the source, I should forked the original and offered patches.
Jan 24, 2026
iBookSpeedster88
The following happened in November, so you all are now caught up with some of the more interesting things I did with my PowerPC Macs...
Jan 24, 2026
Any interest in Palm Pilots?
Separate URL: https://retro.tinkerdifferent.com/
Jan 24, 2026
videodoctor
As I continue work to find the AE hook to run 0dan0's custom code, I wanted to share my current bash script to update 0dan0's freed up...
Jan 24, 2026
videodoctor
I've done a lot of video compression with my professional work, and I use ffmpeg regularly. YouTube is going to recompress anything you...
Jan 24, 2026
Finally - A NeXT Computer (Cube)
So, I just recapped the logic board (it looked like someone had recapped, but the surface mount caps were poorly done, and I wanted to...
Jan 24, 2026
I
indibil
Macintosh LCII failure
I'm updating my previous post, as I didn't have much time yesterday and wasn't fully aware of everything. Today I tried a "modern" PSU...
Jan 24, 2026
PowerRCP-G3
Here is a recap of what happened yesterday. Day 23: I decided to test out sixtyforce on different PowerPC Macs to see which one would...
Jan 24, 2026
6100/66 DOS Compatible
It doesn't appear a 605 would support the card. At the very least, the opening for a network card isn't large enough for the card...
Jan 24, 2026
I want to, but I'm having some sever performance problems. It's way slower than my NeXT Station, which is the same 25MHz 040... I'm...
Jan 24, 2026
