Board Nominations
here.
community projects
, join
GlobalTalk
, and have fun!
P
pixelpusher
Apple IIe: Removing the mounting points of the DSub joystick port
Apple I/II/III
Hello, greetings from Germany! I recently aquired a NTSC Apple IIe, which after inspection showed a bit more corrosion than expected...
Jan 25, 2026
P
phipli
Good morning @AlpineRaven. If you don't mind, I'll have a go at answering. I have a soft spot for Wombat family machines. That's fun -...
Jan 25, 2026
A
AlpineRaven
6100/66 DOS Compatible
I meant Quadra 660av - not 605 - my fault as I wasn't thinking straight Cheers AP
Jan 25, 2026
I
indibil
Macintosh LCII failure
I've checked the solder joints and the traces, and everything's still the same. When I turn it on from cold, I hear the "bing" sound...
Jan 25, 2026
A
AlpineRaven
Macintosh Quadra & Centris
Hey all, As I have Quadra 800 logic board inside Quadra 700 case, it also has DOS compatible card installed with extension to the NuBus...
Jan 25, 2026
OK, I've finally posted my detailed work log on the 1.1.20.1 and 2.26NT ROMs with a lot of commentary...
Jan 25, 2026
