clicking here
videodoctor
Thanks for the effort, @0dan0 ! No hard crash, but the buttons are unresponsive on the unit. Here's the complete output from the "Hello...
Jan 25, 2026
@videodoctor For your initial testing only This build will very likely crash, and/or dump a lot of error messages. I've ported anything...
Jan 25, 2026
Macintosh LCII failure
Do you have an oscilloscope? I would measure this point in the circuit and see if the amplitude declines. You might be able to catch...
Jan 25, 2026
I
indibil
Yes, I already tried that, it sounds the same through headphones as through the speaker. Could it be a UB10?
Jan 25, 2026
PowerRCP-G3
Here is a recap of what happened yesterday. Day 24: I sadly didn't do anything on the Power Mac G4. So, the PowerBook G4 took center...
Jan 25, 2026
If you want to further narrow down the location of the sound issues, put some headphones on or use an external speaker. If the problem...
Jan 25, 2026
Finally - A NeXT Computer (Cube)
OK, I found the reason for the slowness. It appears to be due to the ZuluSCSI or SD card in it. I copied the same HD image over to a...
Jan 25, 2026
K
KennyPowers
I wouldn't think that would be a problem, but is your board socketed? Mine isn't, but I know some Cube boards were.
Jan 25, 2026
