Board Nominations
here.
community projects
, join
GlobalTalk
, and have fun!
From at 2019 to 2025 board date. I think I will have to get a type D unit, both to work the port, and test the quality. What you can...
Jan 25, 2026
videodoctor
Here’s the sensor on my D unit.
Jan 25, 2026
That's annoying, crash or looping error messages would have been easier for next steps. hist.c code will not run without the support...
Jan 25, 2026
I normally leave the white vinyl cover on the solder side of the analog board off so that I can more easily measure voltages at the very...
Jan 25, 2026
The nvramrc script and nvram variables that get modified by classic Mac OS are stored in OFpt resources in the Startup Disk control...
Jan 25, 2026
GreenBar0n
I'm reading very close to the same voltage you listed above in the floppy ports, you're showing 5.04V and a 5.12V, I'm between 5.05-5.02...
Jan 25, 2026
videodoctor
Thanks for the effort, @0dan0 ! No hard crash, but the buttons are unresponsive on the unit. Here's the complete output from the "Hello...
Jan 25, 2026
@videodoctor For your initial testing only This build will very likely crash, and/or dump a lot of error messages. I've ported anything...
Jan 25, 2026
Macintosh LCII failure
Do you have an oscilloscope? I would measure this point in the circuit and see if the amplitude declines. You might be able to catch...
Jan 25, 2026
I
indibil
Yes, I already tried that, it sounds the same through headphones as through the speaker. Could it be a UB10?
Jan 25, 2026
