community projects
, join
GlobalTalk
, and have fun!
That is weirdly wide for a stock lens and unmodified firmware.
Jan 26, 2026
Day 23-25 Misc Stuff I ordered some drive belts, and they arrived, so I was able to piece back together the broken SCSI cdrom drive. I...
Jan 26, 2026
videodoctor
As I'm new to the community, I'm not sure if there's a documented process for doing a full overscan, but I re-installed stock firmware D...
Jan 26, 2026
T
Upgrading IIsi onboard RAM to 4MB
There are four things that come to mind when shopping for that kind of part: 1) Is the shop reputable. IOW, will you get the part...
Jan 26, 2026
zezba9000
Hi, I have a couple IIsi systems (4 actually). I'm trying to validate and source/buy some new modules for these systems but I'm hoping...
Jan 25, 2026
I think so. hist.c should not be called before the new New Preview Res code
Jan 25, 2026
AR0330 2.2um pixels OS04D 2.0um pixels I'm assuming the same lens. Please do a full overscan, need to see the sprockets. The smaller...
Jan 25, 2026
videodoctor
I’ll test again, but that’s where the process froze. We’ll get this solved! Did you determine all four type 4 variables for your host.c?
Jan 25, 2026
From at 2019 to 2025 board date. I think I will have to get a type D unit, both to work the port, and test the quality. What you can...
Jan 25, 2026
videodoctor
Here’s the sensor on my D unit.
Jan 25, 2026
That's annoying, crash or looping error messages would have been easier for next steps. hist.c code will not run without the support...
Jan 25, 2026
I normally leave the white vinyl cover on the solder side of the analog board off so that I can more easily measure voltages at the very...
Jan 25, 2026
The nvramrc script and nvram variables that get modified by classic Mac OS are stored in OFpt resources in the Startup Disk control...
Jan 25, 2026
