clicking here
I am so glad you said that, because that's what I had to do to get the Portable to not crash when playing sounds. I was embarrassed to...
Jan 27, 2026
videodoctor
@0dan0 not sure if this is where i should be putting effort, but I'm on the hunt for setting the default 656x480 capture to 1600x1200...
Jan 27, 2026
techknight
I have occasionally had to bypass the high-side load switch MOSFET for the sound circuitry because it gets noisy if not, 12V hovers...
Jan 27, 2026
I
indibil
LC 630 and BlueSCSI
Hello. Well, I've tried it, and it seems to work, BUT with a catch. I added a 50-pin connector to the ribbon cable, and if I connect...
Jan 27, 2026
P
phipli
Thanks for the update. If you do have any stability issues, they might be most cheaply resolved by just adding a fan to the heatsink...
Jan 27, 2026
constcast
It is just a regular 2-pin header. That picture was with System 7.5.3 which I was able to run overnight without crashing. The CPU gets...
Jan 27, 2026
That would be good for studying words, and I may well use that soon, but we wanted to get a little more information on the PowerPC...
Jan 27, 2026
P
phipli
Excellent news - that was quick :) Your Centris should now be just a hair faster than a Quadra 840av! What System version are you...
Jan 27, 2026
PowerRCP-G3
Here is a recap of what happened yesterday. Day 26: I decided to do some art on the PowerBook G4 for an art challenge. Day 27 is going...
Jan 27, 2026
smrec is the last command on older units
Jan 27, 2026
