community projects
, join
GlobalTalk
, and have fun!
Deano
I think you mean 0dan0 and videodoctor are working on the custom firmware. I'm not a SW/FW expert at all!:giggle:
Jan 28, 2026
I just ordered a type D off ebay.
Jan 28, 2026
iMac G5 ALS 20" Thermal Repair
Also, consider that iMac G5 was released 09-2004 and discontinued 01-2006 so that thermal paste is quite possibly between 19 & 21 years...
Jan 28, 2026
0x2c02b4
Jan 28, 2026
Hot temperatures up to thermal shut down/freezing. Ambient operating range for imacG5 is 50-95F. Apple doesn’t state (at least I’ve...
Jan 28, 2026
_nec6678
Rodime 20MB Macintosh Plus External Hard Drive Capacitor Replacement
Thank you very much! I was able to find the same parts on DigiKey, and put them into this list. The white and translucent ones have 10mm...
Jan 28, 2026
videodoctor
@0dan0 , this is my latest version with just consoleD calls. No crash in this version, but still freezes. Which memory address did you...
Jan 28, 2026
O
Oelmuvun
LC 630 and BlueSCSI
Back in the day I added an extra connector to the ribbon of my 6500. It worked just fine with the HDD mounted upside down in the top of...
Jan 28, 2026
P
phipli
WomBOOST - Very Small Performance Boost for your Wombat
Folks, feedback from someone with a 40MHz 650 is that the extension actually slightly slows down CPU execution, so I suspect the apple...
Jan 28, 2026
P
phipli
It isn't an alternative - it doesn't touch the clock speed. Only the mini wombats, the 475 / 575s have the programmable bus clock. If...
Jan 28, 2026
