Board Nominations
here.
community projects
, join
GlobalTalk
, and have fun!
the 656x480 is the preview pipeline. On a Type C while recording: > ipl getimepath 0 P1: SW:1 Num:6 H:1600 V:1200 LOFS:1600 FMT:102...
Jan 28, 2026
videodoctor
Also, if I use the ipl setimepath command, I'm able to change the preview resolution to 320x240, and visibly changes the UI to show a...
Jan 28, 2026
2026 PowerPC Challenge: the user's Unofficial thread
Do you think the resistor you installed may be slowing things down too much when under load causing added heat resulting in the heatsink...
Jan 28, 2026
Arbystpossum
Re-creaming the G4 iMac heatsink and heat pipes, as well as letting the fan run at a higher speeds helped quite a bit, but I think the...
Jan 28, 2026
videodoctor
@0dan0, not sure I posted this before or we specifically discussed this, but this serial console command shows a 656x480 image size...
Jan 28, 2026
Deano
I think you mean 0dan0 and videodoctor are working on the custom firmware. I'm not a SW/FW expert at all!:giggle:
Jan 28, 2026
I just ordered a type D off ebay.
Jan 28, 2026
iMac G5 ALS 20" Thermal Repair
Also, consider that iMac G5 was released 09-2004 and discontinued 01-2006 so that thermal paste is quite possibly between 19 & 21 years...
Jan 28, 2026
0x2c02b4
Jan 28, 2026
Hot temperatures up to thermal shut down/freezing. Ambient operating range for imacG5 is 50-95F. Apple doesn’t state (at least I’ve...
Jan 28, 2026
_nec6678
Rodime 20MB Macintosh Plus External Hard Drive Capacitor Replacement
Thank you very much! I was able to find the same parts on DigiKey, and put them into this list. The white and translucent ones have 10mm...
Jan 28, 2026
