Board Nominations
here.
community projects
, join
GlobalTalk
, and have fun!
videodoctor
Thanks for the continued investigation, @0dan0 . I'll see if I can get hist.c working now---I did have it calling during preview (and I...
Jan 28, 2026
Type Back to Stock firmware: ipl getimepath 0 P1: SW:1 Num:6 H:1728 V:1296 LOFS:1728 FMT:102 BUF0 Y0xa2730b70 U0xa2953770...
Jan 28, 2026
Arbystpossum
I removed the resistor for the fan, so it's spinning at whatever the G4 thinks is good enough. I don't think I've observed the G4 fan...
Jan 28, 2026
PentaxEnthusiast
Awesome, thanks! I just might have some small fans kicking around somewhere. Currently browsing ebay for a 1 GB memory kit as well...
Jan 28, 2026
videodoctor
You bet, @0dan0 ! Here's the output while recording, with the original stock D firmware: P1: SW:1 Num:6 H:1728 V:1296 LOFS:1728...
Jan 28, 2026
@videodoctor Can you call ipl getimepath 0 while recording?
Jan 28, 2026
Here is a thread on active cooling mods on an iMac G3.
Jan 28, 2026
PentaxEnthusiast
I would love to get some better cooling in the G3 and maybe push the envelope back to 700 MHz, but I'm also wondering if it makes more...
Jan 28, 2026
the 656x480 is the preview pipeline. On a Type C while recording: > ipl getimepath 0 P1: SW:1 Num:6 H:1600 V:1200 LOFS:1600 FMT:102...
Jan 28, 2026
videodoctor
Also, if I use the ipl setimepath command, I'm able to change the preview resolution to 320x240, and visibly changes the UI to show a...
Jan 28, 2026
Do you think the resistor you installed may be slowing things down too much when under load causing added heat resulting in the heatsink...
Jan 28, 2026
