Board Nominations
here.
community projects
, join
GlobalTalk
, and have fun!
GreenBar0n
Regarding only getting 1.305MHz at A(2) Pin 4 - when the ROM is removed: I think the Simasima Repair Guide was stating what the...
Feb 4, 2026
Official Tinker Different Poll: Board Size Reduction
Aye! 3+2=5 in the decision making process is a very workable number. We had a larger board of directors/officers at NYMUG back in the...
Feb 3, 2026
N
NJRoadfan
Apple ][ Card Audio Characteristics
The speaker jack on a real Apple II has +5v on one pin and the other pin is the sound output from TTL logic routed thru a bunch of...
Feb 3, 2026
P
phipli
I appreciate the thoughts, but there are still several options, that isn't a show stopper. I could for example, remove R899, or, as I am...
Feb 3, 2026
N
NJRoadfan
Other than R899, which appears to be a pull up resistor. That may be a show stopper from using this pin as-is.
Feb 3, 2026
P
phipli
Pretty basic - it mirrors the signal coming out of the DFAC for the host's sound on the LC and LC II. Blue is straight out of the DFAC...
Feb 3, 2026
N
NJRoadfan
What does the circuit look like between the PDS slot pin and the audio output? Its likely it attenuates the 5V TTL signal down to line...
Feb 3, 2026
fxgogo
That makes SOO much sense. Thanks for the explanation.
Feb 3, 2026
Stinkerton18
I can answer that. It stems from an issue that's occurred in a couple other communities, some non-retro computing, where things like a...
Feb 3, 2026
