2026 PowerPC Challenge: the user's Unofficial thread
Yay! It finally arrived! 160GB 2.5" IDE drive in what looks to be factory antistatic bag nestled nicely in bubblewrap into a box showing...
Feb 4, 2026
jonschwenn
Newton eMate backlight hum
iPad, iPod, Newton/eMate & Handhelds
I had a mostly working eMate that needed a hinge repair and was not recognizing touch events. I rebuilt the hinges and replaced the...
Feb 4, 2026
DatMac
Color Classic Flyback Replacement from LC5xx
How is it since you did this? is it still working good? I have my CCII i recapped but it likes to arch and loose HV every now and then...
Feb 4, 2026
Mark_W
I took another look at the repair guide: And on page 46 the scope shows square wave with 50% duty cycle, and its measurement is indeed...
Feb 4, 2026
GreenBar0n
Regarding only getting 1.305MHz at A(2) Pin 4 - when the ROM is removed: I think the Simasima Repair Guide was stating what the...
Feb 4, 2026
Official Tinker Different Poll: Board Size Reduction
Aye! 3+2=5 in the decision making process is a very workable number. We had a larger board of directors/officers at NYMUG back in the...
Feb 3, 2026
N
NJRoadfan
Apple ][ Card Audio Characteristics
The speaker jack on a real Apple II has +5v on one pin and the other pin is the sound output from TTL logic routed thru a bunch of...
Feb 3, 2026
P
phipli
I appreciate the thoughts, but there are still several options, that isn't a show stopper. I could for example, remove R899, or, as I am...
Feb 3, 2026
N
NJRoadfan
Other than R899, which appears to be a pull up resistor. That may be a show stopper from using this pin as-is.
Feb 3, 2026
P
phipli
Pretty basic - it mirrors the signal coming out of the DFAC for the host's sound on the LC and LC II. Blue is straight out of the DFAC...
Feb 3, 2026
N
NJRoadfan
What does the circuit look like between the PDS slot pin and the audio output? Its likely it attenuates the 5V TTL signal down to line...
Feb 3, 2026
