Board Nominations
here.
community projects
, join
GlobalTalk
, and have fun!
croissantking
PowerBook 500 series PPC upgrades
No because the 28 pin chips are 8bit wide so you need a set of four on a 32-bit bus. The 42 pin chips are 16 bit wide each, so you only...
Feb 8, 2026
VicNor
Advice wanted: epoxy replacement on flyback
Compact Macs
I got a machine with a good analog board, but the flyback looks a bit rough around the epoxy with some indication of arcing. I remember...
Feb 8, 2026
VicNor
Mechanical issue with Miniscribe
Compact Macs
I kept a Miniscribe from a SE that I restored and sold off a couple of years ago. I've only got it to spin up twice - both involved...
Feb 8, 2026
robin-fo
Macintosh SE sudden death: burned chip on logic board + suspected analog board capacitor leakage
Stop!! That‘s the 26LS30, not 26LS32! It‘s the serial driver IC. You need to get these second hand. Did you overload your serial ports once?
Feb 8, 2026
PentaxEnthusiast
After discovering yesterday that the 770s hard drive appears to be dead as well, I've given up on doing anything with it for the time...
Feb 8, 2026
