haydonbeagley
PowerBook G3 Lombard (Bronze Key) ODD Rebuild
PowerBook (PowerPC-based)
Hi all, Long time reader, newbie poster! I recently came to own a Lombard through a friend who does IT clearances and it found its way...
Feb 8, 2026
VicNor
Advice wanted: epoxy replacement on flyback
Thanks a lot! What kind of silicon do you use? Are we talking normal silicon you use when working on your car?
Feb 8, 2026
victor.muc
Macintosh SE sudden death: burned chip on logic board + suspected analog board capacitor leakage
Thanks for the correction! Regarding the serial ports: a few days before the failure, I briefly connected an Apple RS-422 cable to the...
Feb 8, 2026
L
larryc39
I found single-piece orderable lens mounts that are the same size as our original. If you're replacing the lens it might be just as...
Feb 8, 2026
P
Paolo B
Just my experience, but some other people may have different opinions, more educated feedback. The epoxy blob has no actual...
Feb 8, 2026
croissantking
PowerBook 500 series PPC upgrades
No because the 28 pin chips are 8bit wide so you need a set of four on a 32-bit bus. The 42 pin chips are 16 bit wide each, so you only...
Feb 8, 2026
VicNor
Compact Macs
I got a machine with a good analog board, but the flyback looks a bit rough around the epoxy with some indication of arcing. I remember...
Feb 8, 2026
VicNor
Mechanical issue with Miniscribe
Compact Macs
I kept a Miniscribe from a SE that I restored and sold off a couple of years ago. I've only got it to spin up twice - both involved...
Feb 8, 2026
robin-fo
Stop!! That‘s the 26LS30, not 26LS32! It‘s the serial driver IC. You need to get these second hand. Did you overload your serial ports once?
Feb 8, 2026
