PowerBook5,2 15" rescue
I vote for the steam roller. :D
Feb 9, 2026
Y
Yoda
Official Tinker Different Poll: Board Size Reduction
I'm rather leaning towards 'no', but mostly because it feels like a move to fix the wrong problem. The direction really needs to be...
Feb 9, 2026
victor.muc
Macintosh SE sudden death: burned chip on logic board + suspected analog board capacitor leakage
Good to know! If the connection should have worked with just the cable, then a preexisting fault in the IC does seem plausible. What...
Feb 9, 2026
videodoctor
@0dan0, in Type A/B/C mods, were you able to identify an address that stored the current buffer address that was being drawn to? I saw...
Feb 9, 2026
hist.c is up to date. I did have the flicker, which just means it need to be called form somewhere else.
Feb 9, 2026
videodoctor
@0dan0, can you share your last version of the hist.c for that display? did you have that blinking issue I had?
Feb 9, 2026
Before my unit died, expo_iso at 0x80e5590c was working for me. The display of ISO value changed correctly as light was controlled.
Feb 9, 2026
videodoctor
Ok, thanks for that input, @0dan0. I've started to use the BSim plugin with Ghidra and the AE function I was working with before in...
Feb 9, 2026
Just me, working on top of Steve's initial work.
Feb 9, 2026
