Board Nominations
here.
community projects
, join
GlobalTalk
, and have fun!
jeffburg
iMac G5 ALS 20" Thermal Repair
Sorry, I don't have a solution to your problem. But I remember those iMac G5 ALS models as being so cool when I was a genius at the...
Feb 12, 2026
thecloud
Interesting. They also forked the same sit.c file from 1988, back in 1990. Looks like the only addition is to stick the FInfo in a...
Feb 12, 2026
videodoctor
Thanks for posting this! I didn't realize my heat gun was set as hot as it was---I partially melted one side of the mount while I was...
Feb 11, 2026
L
lsi-aigisx86
Identifying mystery macintosh SE Accelerator/upgrade card
Wow, good stuff everyone, I'll probably take phipli's suggestion and clean/reseat the accelerator card, or maybe swap the memory from my...
Feb 11, 2026
P
phipli
I would assume the card has memory that worked at some point and is set up right. My assumptions would be that the contacts on the...
Feb 11, 2026
P
phipli
I'd be suprised if it was VGA - are you sure it doesn't have 9 pins? It does do video out - depending on the option yours came with...
Feb 11, 2026
P
phipli
Yeah, as others have said that looks like a Mobius. You can either use their drivers, or the GemStart driver works just fine with it...
Feb 11, 2026
