LC575 computer killed LC520 motherboard! 😭
I sadly didn’t re-test the LC520 motherboard inside my CC Mystic immediately prior to testing that motherboard in the 575 chassis, but I...
Feb 13, 2026
I have a Performa 575 and have successfully used both 520 and 550 logic boards in it with no problem, boards that I normally use(d) in...
Feb 13, 2026
Marcio D.
SHADOW GANGS ZERO - Retro-style ninja action game for Neo Geo, Sega Genesis / Mega Drive, and Dreamcast !
The developer has dropped a major bombshell in his latest update report. Despite Neo Geo having been the lead development system since...
Feb 13, 2026
I put my multimeter into continuity check (beeper) mode and put the probes across each polymer tantalum capacitor. No continuous beep...
Feb 13, 2026
With the motherboard removed, do you measure a short between +5V and gnd on the motherboard?
Feb 13, 2026
L
lsi-aigisx86
Identifying mystery macintosh SE Accelerator/upgrade card
The voltage with the card installed reads at 4.90v, without the card installed, the voltage reads at 5.00V Some more updates, I...
Feb 13, 2026
P
phipli
What did the 5v actually read as to 2 decimal places?
Feb 12, 2026
L
lsi-aigisx86
So updates, I have been able to confirm that the power supply is good, both with and without the accelerator that 5 volt and 12 volt...
Feb 12, 2026
When I tested my LC520 motherboard inside the LC575 body, I had my external BlueSCSI v1 attached, but its LEDs never lit up. I...
Feb 12, 2026
The LC520 motherboard was recapped by me using these Polymer Tantalum capacitors.
Feb 12, 2026
