VicNor
Mechanical issue with Miniscribe
This bugger. How do I remove it? Is it possible? Do I need a special tool or is it bulted on so it's impossible? I've tried to lift it...
Feb 15, 2026
Macintosh Slice - a Pre-release Color Classic
A different Color Classic came with its instruction manual. It includes a brief insert that calls out the power-up sequence. There must...
Feb 15, 2026
I just repaired another Portable that was crashing when sound played. I decided to put this board in my ultrasonic cleaner. Afterwards...
Feb 15, 2026
LC575 computer killed LC520 motherboard! 😭
It might just be a bad joint (your solder joints seem good). I've had capacitor gunk get under a leg and eventually disconnect when...
Feb 15, 2026
clwelch63
OK. The jitter was my fault. I wasn't using all of the windings on the uptake reel. After threading the file properly, it is working...
Feb 15, 2026
clwelch63
I was able to capture using a 32GB card. Thanks! However, the frame jitter is very noticeable.
Feb 15, 2026
T
twvd
Anyone remember the OJ Simpson chase animation on older Macs?
Works on Snow
Feb 15, 2026
Byte Knight
Mac IIsi Repairathon
Looks great! I added a TechWorks Ethernet / FPU PDS card and a DayStar IIsi cache adapter / 50 MHz 68030 accelerator to mine - it's...
Feb 15, 2026
B
BigBadBiologist
DosFox came up with a way to program replacements, but finding the blank chips is difficult and the programmer is special. I don’t know...
Feb 15, 2026
You've done a lot of board repair on your YT channel, so I really appreciate your kindness in making time to offer me feedback. If...
Feb 15, 2026
