VicNor
Mechanical issue with Miniscribe
Thanks! I'll try to goto the hardware store next week to find a spanner tool that'll work.
Feb 15, 2026
mnthund3r
Apple Network Server 700 boot issue
Xserve & Servers
I have an ANS700/150 that I've had sitting in my basement for 25 years. recently tried to start it up, and it won't boot past the 0>...
Feb 15, 2026
That looks to me like a threaded on nut, that probably requires a special spanner tool. You can use a needle nose pliers opened up to...
Feb 15, 2026
VicNor
This bugger. How do I remove it? Is it possible? Do I need a special tool or is it bulted on so it's impossible? I've tried to lift it...
Feb 15, 2026
Macintosh Slice - a Pre-release Color Classic
A different Color Classic came with its instruction manual. It includes a brief insert that calls out the power-up sequence. There must...
Feb 15, 2026
I just repaired another Portable that was crashing when sound played. I decided to put this board in my ultrasonic cleaner. Afterwards...
Feb 15, 2026
LC575 computer killed LC520 motherboard! 😭
It might just be a bad joint (your solder joints seem good). I've had capacitor gunk get under a leg and eventually disconnect when...
Feb 15, 2026
clwelch63
OK. The jitter was my fault. I wasn't using all of the windings on the uptake reel. After threading the file properly, it is working...
Feb 15, 2026
